Bar Extenders (Insight, Ideas and Interest)
jimvandeveld
Today I made a set of bar extenders after seeing some in the Your Scooter thread, and realizing that I'd love to keep my current bars as well as have some added width.
I'm making this thread to see if I can get 10 people to commit, but not pay up front, for some bar extenders and go from there. I am planning on making them in 0.5", 1", 1.5" and 2" sizes. Anything more than that and I'd be afraid of them getting weak. I made mine out of some pretty gnarly Nylatron composite Plastic, and added an Interated bar end onto the end.
What I did was make a 3/4" long shoulder of a diameter slightly cleared to the inside of my bars and then stepped it up to the 7/8" OD of my bars, which in this case ended up being 1" long. I then slipped the bar end into place and drilled a hole through my bars and right into the plastic inside my bars to make sure everything was on location. In my case, I drilled the hole with a #21 drill, which is the tap drill size for a 10-32 screw. I'd obviously do this for you guys, to a known location say, 1/2" from the edge of of bars so all youd have to do would measure, mark and drill so all you'd be responsible for is drilling the clearance hole in your bars. I'd supply the necessary hardware.
Anyhow, the design is super simple but functional. Please share your comments and ideas and interest, and if I get a few people interested ill make some pairs up by the weekend.
-Jim
DerekS
Why dont you make the end like a normal barend? Thatway as you tighten the bolt on the end the inside will expand and lock into the bars?
Chris Weik
how about a giant solid odi bar end? just like you push it in and done, the starnot type idea would pull the star nut out on big drops
jimvandeveld
good idea, but make it so that stupid bolt doesnt stick out, countersink it in
Can't countersink it in with such a thin wall thickness man. What I would like to do is tap the hole in the bars and tap the extender and just use a set screw and it'd be flush. That be great for me but not functional for people without access to a tap.
jimvandeveld
I had thought of that, but thats what I meant when I said its not functional to do that because I'm making everything manually, it would take too long and cost too much to do it that way.
DerekS
No, i have friends who actually did this idea and it worked perfectly.
What you would need:
x2 of the old inward pegs
x2 Top Cap bolts
x2 7/8 starnuts.
Put the starnuts in, put the bolt through the hole in the peg, tighten it in.
