hey rob, when using a sealed headset on threaded forks, you would just use the locknut as compression right? and why is it such a bad idea using threadless compression with threaded forks?Alright, I can't believe the amount of stupid I'm reading.
1: do not use compression with threaded forks. if you do, you're doing the stupidity equivalent of drinking antifreeze. threaded forks only need the threaded nut to compress the headset. If it comes loose, buy a small tube of blue locktite (the color makes a difference) and locktite the threads 1 or 2 threads ABOVE the headset cap.
2: there is no problem using threadLESS headsets with threadED forks. I actually suggest this, as threaded headsets suck.
No, it's not even preference. In your analogy, it would be like tying an hourglass to your wrist, to know what the time is.
There's no point in doing it, don't do it. It's a waste of time.
We're not talking about what you like better hes asking if you can use ICS on a threaded fork, And Rob never even said that he liked threaded more.
But you came out of no where saying which one is better, the question was COULD YOU USE ICS ON THREADED FORKS. I just don't see why your trying too answer that threadless is better then threaded in here
haha i guess your KINDA right but i still disagree i like threadless way better than threaded, it feels better. thats preference
Kinda seems like you were, but whatever not trying to pick a fight here lets be on our ways.
