red ring of death.
unplug all of you cords from the x box and all the x box cords from your tv and the power outel and take out the disc and just let everythng sit for like 15 minutes and make sure you plug everything beck in CORRECTLY and if it doesnt work your fucked.
Bear Grylls
M3MB3R
iHad it befor idid the towel trick .And it worked how many rings do you got
ADNpro
<b>REEEEEEEEEEEEEEVES</b>
Never do the towel trick. It just fixes it for a couple days and actually just causes more damage.
It's so much easier to just take it apart and apply some new Arctic silver 5 to the GPU and CPU and shim it up. Just fixed one last night using that method.
ps3 burn out faster
take apart the xbox take all the dust out put it back together should work like new after that
are you retarded? pretty sure EVERY xbox with the exeption of like 20 has got rrod every kid in my school that ive talked to had it.. microsoft KNOWS that its going to happen thats y it lights up red .. so insteasd of fixing it so it doesnt happen they just charge you to get it fixed
Brian Boston
ps3 burn out faster
Not being a fanboy or anything, but PS3 failure rate is less than 1%. 360 is somewhere between like 30-40%, although these numbers are just from googling around.
Out of my friends that have 360s, like 5 out of 6 have got red rings. Out of my friends with PS3s, 1 out of 5 has had something go wrong... that was mine that my dad over heated, user at fault. Pretty sure the only thing that can happen to your PS3 is your bluray lens burning out that you can fix yourself for about $50 if you have the balls to remove a few screws and ribbon cables, but this probably won't happen to your PS3 anyway.
Anyway, just send that shit in or buy a new one, or start some shit with them over the phone and see if you can get a free fix out of it.
ADNpro
Truth. 360s do have an extremely high failure rate. Only reason I bought one was to play Forza 3. And the one I bought was a red ringed elite that only cost me 50 bucks. I Fixed it and now I'm all set.
charliemein
im not trying to start another fight but 3 in 30 of freinds have had rrod and one of them was mine, and i fixed it the night in happened and the rest of them have had there xbox's replaced for free and given sumthing aswell
