rotorwhips clean flat help
instinctscooter
i can sketch rotor if i whip oppo bar but if i try to normal bar my scooter flies away even if i lean over my scooter. any help on the timing, ALSO i tailwhip and bar clockwise not opposite directions so that affects things, help is as always appreciated
Kevin Tuohy
i do the same as u (bar and whip the same way) but there's not much tricks except to lean forward, throw the bar RIGHT after the whip, and to practice and commit
TomGeorge
Dont lean back. Everyone does, it's unnatural to bar right into your body but get as close as you can to the position you would be in for a whip. Whip it as slow as possible as it gives you more time to focus on the bar.
