Stuck bearing case..
Ben.
Oky, so im getting REALLLLLLLY fucked of. My case that the bearings in is stuck in my wheel. Any help, Btw, a flathead and hammer dont work -.-
BrandonWeir
I'm afraid I don't understand the question. Your bearing is stuck in the wheel? Or are you trying to get the little cage cover thing off so that you can lube them up?
Ben.
You know on the bearings how they have the metal ring on the outside? everything on the insides gone, except that metal thing. Hope you understand :\
ConnorD
Ahhhhhh that is reallllyyy shitty bro :(
Not too much you can do there, exept for cut a slit in it and then pry it out. Pretty difficult though.
BrandonWeir
Oh I know what your talking about. This is one of the biggest bitches of problems. Did you try putting the bearing back together? If you have all the balls and the smaller ring, sometimes you can get it back together if the smaller ring is fucked up and knock it out. Other than that, you can take a grinder and be very precise and try to cut it and get it out somehow. Idk this is really tough. But I've seen the mission accomplished in those two ways.
BrandonWeir
Take it to someone who knows their shit (maybe a bike shop or a hardware store, although it's usually a stretch) and see if they have any wisdom for you. What kind of wheel is it stuck in?
this happened to me a bunch of times with my demons, go find the skinniest flathead you can, the stick it between the center of the hub and the bearing (it will barely catch keep trying til it does) the hammer it out, you have to do it from the opposite side of the bearing that is stuck, so you can hit it out from the other side, took me like 30 minutes to get mine but it worked...
did you get it out yet?
theres that ring in the middle of your hub and the ring is stuck against it? flip it over, the find like a hole in the ground the the ring is hovering but the rest of the wheel is held up then just hammer it around in a circle, it will slowly press the ring out if you switch sides a bunch it helps to evenly push it out once it starts its pretty easy
Victor C.
oh im lucky this exact same thing happened to me yesterday, but it easily came out. just keep trying it will come out eventually
