yak metal cores or yak plastic cores? (front wheel help)
DevonIs1337
currently running an eagle in the back... but i'm curious as to what wheel i should run in the front.
i ain't gonna lie, i really like how the scat metal cores look, but i've heard/seen some really bad stories/reviews/etc.
is it still better than a standard plastic core, though?
Tom Cirbee
probably. the only tings i have heard negatively were the plastic bearing cups breaking and ovalizing. I also heard that the urathane slides.
*to be honest. i heard that the yak USA is a good wheel. depends what size your eagle is.
ridescooters3
yak scats suck, the urethane starts to chunk like the first day. If they don'nt chunk then they are pretty nice. I am running one in the back right now, the bearing cups are so loose and mine is chunking.
CTRider
Yak skats are fast but the bearing cups need to be epoxied and they dehub easy. Half the urethane on the wheel has simply broke off on all 4 of my skats. If they were bonded better to the wheel I would buy more for the price but even on the front I broke the urethane half off the wheel.
Ben Para
if you ride them in front they arn't really that bad but mine had like airbubbles in it and when i started to wear it down it had these air pockets
