buff bar problem
so i have buff bars and and regular stock pro model fork. When i put my bars on and tighten everything as tight as i can the bars still manage to wiggle. its very annoying to ride now.. ive tried to put duck tape it still didnt work
any ideas please share
Chase Robertson
Your headset is probably loose. Take your bars off, tighten your headset, then put your bars back as far down as they will go and tighten your clamp good.
Chase Robertson
Well what is wiggling on what?
The bars wouldnt be wiggling on the fork, because i know from personal experience that buffs fit fine on stock forks.
It would have to be either the headset or the foldy. Is your foldy bolted?
JGOOD
i have buffs also the only time my bars wiggle on stock forks is when my headset is lose or my foldy isnt bolted good enough. tighten everything up and if u have another clamp throw it onto your bars.
Joe Riley
The Gypsy
wait, are the buffs new or old? josh kish had a problem where his stock fork threaded the bars and made too much space and they wiggled.
same thing happened to my sz 3peice bar, i just took of my bar and put tape under so there is now room for wiggle. problem solved. make it un noticeable tho.
