Basically I got an Idea before for compression. Basically Your fork has a starnut in it. Fork goes up decks headtube, Shim goes over forks and you tighten top cap and bolt into the starnut like HIC, then you slide your oversized clamp on. After that you put a shim in clamp then bars into clamp. If you didnt understand that heres a photo (5 minute paint job <3)
So I was wondering if this would work. Thanks, Layne.
