Compression system/SR fork
briflip
ok ok ok i know this might sound dumb but i dont get it
u buy a threadless fork right
do u then but a compression system or does the system come with a threadless fork as well
help me its confusing for me
Steezeman
No they don't come together, you need to buy both the fork and the compression system. You could've easily figured that out by reading any of the various threads on the forks, as well as the description in the store.
blanket687
how do u buy off of sr because it says to order on the new thread but then the threads say to buy at the store. of compression system
Madis
Super Geek
No, there's two types of compressors. It depends on the starnut's size. Wether or not you're riding regular standard size Razor bars, then you'll need the standard sized starnut, but if you are riding aftermarket bars (SS, RAD, customs?) with oversized steertube, then you'll need the oversized starnut.
fashow69
ok to all newbs who can't figure it out. 1. the fork and the compression sys. come seperatly. 2. you buy them in the "store". 3. if you ride a pro model or any of the newer Amodels i.e the razors that you see in walmart now a days, then you need the fork that is specified to the Promodel and New As. same goes if you ride the Older models from the year 2001 through like 2003. cmon people just look for yourself and use common sense and READ shit first.
