This is on a Lucky Crew for my six year old son that rides it a few hours every day since he got it this last summer. I've replaced both the front and rear stock bearings with Red's Bones yesterday. Factory bearing spacers are installed. Axel bolts are tight. I've rebuild the headset so it's like butter. Two brake bolts are tight as well. Still hear a "braagggg" sound from the back end when you drop his scooter on pavement. I used to have it dialed after I replaced bearings the first few times however nothing I've noted above fixes this sound now
Does the seam between the bearing and wheel get worn to create noise? Do the axles eventually need replacing due to wear?
Thanks in advance.
Thanks in advance.
