Tobin
allright so i have a district v2 deck, everything on it was fine until my friend decided to tighten the hell out of my axels to make it more dialed he tightened it so much the wheels didnt move when u spun them but i could ride it normally when i was actually on it.then it started making a retarded noise then an even worse noise so i took off the wheel and the bearings were fu.cked so i got new bearing and put them in then put my acel in and tightened it as much as i could but the wheel was still loose and moved if u touched and jimmied it around and when you spin it it makes a weird noise, sorry if this is a stupid question or something but basically what im asking is how do i fix it so that the wheel isnt loose and it doesnt make the noise, plz dont say tighten it because i cant thanks in advance
