HD Compression (scs)? help please.
Jon.
It's probably 2 inches higher and I remember seeing it a long time ago. It should work with ultra pro bars and I don't think anyone actually ever had it.
xiodinc
Site is old, but you can still buy one right?
also, does this compression system work with threaded forks? i assume you just put a starnut in the fork with no problems.
stick to the lock nut, keep your life simpler.
VNC is dead
dont buy compression, or at least dont use compression until you NEED compression.
