HELP!!! I CANT FIX MY SCOOTER
STS
Okay. so the problem with my scooter is that when i am riding, the wheel turns to the left, and my bars stay strait. so the wheel is uneven. so i have to loosen my clamp, and tighten it all the way all over again. when i only had extentions, their was no problem. but since i got my 1 piece thredless bars, the bars started turning. and i tighten my clamp as much as possible but the problem still happens. also, my fork is a little dented. should i tighten my clamp as hard as possible, or get a new fork or what?
giggity1
tie it as tight as possible? why wouldn't you do that? lol and do you have a slit in the bottom or are they scs compatiable
get a shim for your clamp
get a smaller clamp for your bars (1-1/4?)
Is your fork threadless?
mat
PinkForRyan said:
THREADLESS BARS? lol you need scs compression system...
you're wrong and dumb. dont give advice if you dont know what you're talking about. all bars are "threadless", it doesn't make a difference. and NOBODY needs an SCS.
is it a threadless fork? and what kind of clamp do you have?
No. No bars come with threads. This kid might not have a slit. If there is no slit the bars cant clamp onto the fork. And i agree with mat.
i have the same problem some times and run a stock fork with c4 bars and a standard 1 1/4 clamp.........and i don't get it either but i really don't care to much i just straighten it with my feet haha
