help with droping in.
ummm like into a qp? if so just come at it with a bit of speed,tap the deck on coping and roll down. once you got that the come at with a little more speend and just jump and point the front of the scooter down and then you will have it
ConnorD
dont hop in straight away, start by dropping in putting one foot on the ground and just leaning into the transition. Then once you get confident you can hop in
Patscooters
start with little ramps and work your way up to bigger ramps.
the first and easiest way to learn is putting one foot down and pushing off.
the second way is to put two feet on and lean forward and use your momentum to drop in.
the third way is called a nose blunt where you put the part of the deck where the headtube and the deck meet and push forward.
the last way is to go from the side with some speed and jump in.
