help with some tricks
Sockz
when i try to 180 whip it looks like im doing a retarded tailwhip and i dont even get my body bast 90 degrees it makes me mad i also need help with heelwhips/oppo whips when i try thoes i cant get it to were i flick my deck my feet just stay on the deck and my deck goes sideways
alexallupinthis
i just started getting them, work on your wrist and throw really hard with you feet then work your wrists like a mutha fucka! works for me
Bill
With the 180 whip turn your head the way you are spinning and look where you want to land. With the heelwhip you kinda have to use the bars to help it while giving a good kick.
Riley Hughes
on the 180 whip, catching the whip is pretty much the only way you're gonna land it. and the heelwhip, well it doesn't sound like you've practiced very much at all. that is the key. make sure to kick it well, then use your wrists.
Robert
Tr0ll
try them on a quarter and whip late on it and you have to know how to whip catch flat it helps a lot and when you feel the deck coming under your feet slam down and when you get that down then start to work on fakeying out of it
Darwin.
on the 180 whip jump high and rotate your body
try them on banks,get them super dialed and then try it on flat
for the heelwhip learn the motion first! i had the same problem when i was trying to learn them
