HIC Help
Patscooters
I SEARCHED
I am using the lucky hic kit on a scorcher with a Cane Creek S-3 with rad crows and a proto half knuckle clamp. I put the shim on and tighten it as much as it goes and it wont tighten any more the headset still wobbles a ton and the shim spins if you touch.
PLEASE HELP
humpurple kushiones
either check to see if the forktube it too long. and make sure the crownrace is on. its not the starnut before someone says that the star nut isnt in deep enough, check to see if the starnut is broken though.
Jon.
you don't need to cut the fork down just put a spacer on before the shim to raise it up. That's what I did.
