hic problem
masciman3
i just got the pry bars w/ hic from lucky. i got everything on and every trick the headset wont stop becoming loose. the starnut is not stripped i checked
no, thats not the problem. dh pros dont come with a compression ring. ive owned two, and they were both dialed. locktite
Jon.
well my sealed one came with a gold compression like ring in with the top bearing so if yours doesn't have that then yeah it's the problem.
i thought a compression ring was like what comes with a cane creek, if you pick up your deck with the compression ring put on your fork wont fall out. or maybe thats called a pinch ring
masciman3
the gold ring is the upper bearing race and it definantly doesnt come with a compresson ring. the installation sheet listed all the parts and the compression ring wasnt there. it seems to be staying now. will locktite make me not be able to take out the bolt?
Nick Griffin <3
i think it might be the shim because when i ordered my lucky pros they didnt give me the shim so i cut the bottom off old inward bars and had to hammer it on and probably didnt even need the top cap
