codyferner
I have found out how to fix chunked metalcores!!!
If you chunk a wheel (not dehub) you are able to glue the chunk of urethane back on it
Step 1: Buy some Gorilla Glue (Only Gorilla Glue works because it sticks to urethane and is urethane based glue)
Step 2: Get the piece of broken urethane and apply a generous amount of glue to the spot where it chunked
Step 3: Clamp the broken piece to the said spot by using a brake and vice
Step 4: Tighten the vice and let it dry for 2 hours
Step 5: When its dry cut the excess glue off of the wheel because Gorilla Glue foams up.
Step 6: Its Done!!!
FIXED METALCORE!!!
If you have any questions please ask
Step 6: Its Done!!!
FIXED METALCORE!!!
