ICS problem!
eku5
i have district v2 deck , i bought proto ics,proto SenioR and a district pro headset , i but all together but if i shake my handle bars i can still see that fork is sloshy , ICS is screwed so tightly as possible but still is a trap between fork and headset , what to too ,should i put starnut deeper in handlebar?
Mikey G
Loosen your bars and tap them down with a rubber mallet. Then WHILE THE CLAMP IS STILL LOOSE tighten your ICS bolt down. After that tighten your clamp and put your wheel on.
Carson .
dont be a douche. your starnut may not be high enough in your bars to allow the bolt to tighten all the way.
