need scs help now!
Jacobo
how much do you tighten the scs bolt(the one that goes into your starnut)
as tight as it goes?
somewhere inbetween?
thx a lot
Can
If you want it dialed, tighten it all the way. Sometimes you can still get it dialed tightening it a little less than all the way. If you have it half way it will wobble and be undialed.
Jacobo
i tightened it all the way, but then i didnt spin at all when i put the bars on....
it a brand new blunt headset that i just opened from the case so idk whats wrong
Can
blunt headsets suck. so loosen it a tad.
Jacobo
ya i loosened it and i realized i didnt have the compressioncap on
and i put a shitton of bike grease on it and its workin perfect:)
Grant Schofield
if i doesnt spin when you tighten the compression then that means you have no crown race/itsnot on all the way. do not tighten the compression all the way youll snap the compression bolt tighten it until it get kinda hard to turn
Micah.
i tightened mine almost as much as possible, and it gradually loosened but was still dialed. I love scs
OwenP.
i tighten mine all the way so it hardly spins but when you put your bars in it spins nicely and takes longer to get loose.
tighten it, but not to the point where it will fuck your bars, that can happen xD and just dont over tighten it cuz that'll ruin the bolts my friend
you misunderstood him ^^ and until you can feel that it is getting hard to turn, the weight of the bars will make it spin better, and it will gradually loosen up to a nice point
