Pro Model Brake Makes Rattling Sound
Domsicle
Put a penny or a nickle under your brake spring or try tightening the bolt, my blade break was rattling and I just had to tighen the bolt to fix it.
Post if that helped.
DMazz
yeah i take off the brake and bend the spring takes me about 10 min haha.. but on my current skoot i was too lazy so i took an old bearing that was broke and i put it under the spring then put lock tight glue which turned into like a hard plastic and its really solid now
AaronA
yea i just put 1 bearing on the part of the spring that hits the beck and a nut on the part of the spring that hits the brake its soo good it makes it stiff as anything
Jarryd M
I had a similar problem, I used a coin under the brake spring which worked great until it fell out so I decided to try tightening my brake spring which ended up working perfectly.
Steezeman
Jake ODonnell said:
Alex Steezeman said:
It's better to just take the brake off and bend the spring so it's tighter, but that takes more work.
and it takes the usual person an hour to put on a brake.
Also true, especially if you have a Blade brake or if you bend the spring too much.
idk47
That means your bolt must be bent, or it was just really loose. Once that bolt turns it will rattle again, unless somehome your locknut came loose %-6
scootcb
l0l. wow. tightening the bolt.. dont u think you couldve expiermented with it more before you posted a thread about this.. becuz there is alot about this. and you couldve posted in help with '_____' part. or w.e its called.
