Replacement ada clamp
jeff26
depends what size it is.. the crossbar should fit because its a bmx stem and bmx bars re 7/8 same with buff bar crossbar. also the steer tube might, because most bmx forks i think are 1 1/4 so it might work.
Jdbug_rob
How many centimetre thick are bmx forks, and wich is bigger out of
Bmx fork - 1 1/8"
Andrew's steertube - 1 3/8"
and by how much?
the_SD_local
I own SR.
Bmx fork - 1 1/8"
and by how much?
I think you are confused...
BMX stems mount onto 1 1/8" BMX forks.
ADA stems mount onto 1 3/8" steering columns that fit OVER 1 1/8" forks.
Wall thickness has nothing to do with how a stem will fit the only thing that is important is the outer diameter (OD).
To answer the question (which Pete already did)... no.
