scooter problemm.. please help
scott s
Scott Scerbo
ok so my scooter when i ride it it feels solid but when i drop it off the ground to see if it sounds solid its pissing me off its like either the brake or back wheel so idk please help me though..
Michael Rankin
if its the back wheel, then tighten the wheel. if its the brake, wrap a nickel in electrical tape and put it under the brake spring
scott s
Scott Scerbo
back axel is extremely tightened i have a baring in the spring crazy hotglued that why im so confused!! lol p.sp are you related to patt rankin?
scott s
Scott Scerbo
nope my scooter is in the scooter of the month if that could help i could also take pics of the back of my scooter
Michael Rankin
put tape in the bearing hole on your back wheel.
it may also be your deckplat. take the deckplate off and put a layer of electircal tape on top of the frame and your scoot will sound way more solid.
Michael Rankin
oh my bad, when you mentioned sotm i thot you meant that the newest sotm was yours. yeah i dont know what is making the noise on your scoot right now. and btw, who is patt rankin?
superman
yeah something happened to me like this too is your brake a razor stock if so then the hole where the bolt goes through gets like messed up and i ended up drilling a bigger bolt on now my scooters sounds so solid
proudlefty
OK, so, I think Simon was on to something. Here's what happened to me. My back wheel had the bolt unscrewed so long and I rode it so long with it like that, that the bolt starts to file away at the hole in the deck until it is much bigger. Then even when your bolt is tightened it can still move around because of the bigger hole in the deck. That has happened to mine and maybe that bigger bolt thing would work but it would still have to fit into the socket of the whatever goes through the back wheel. Hope it helps.
scott s
Scott Scerbo
thanks proud lefty and i have a blade brake the brake is ot the problem i took off the brake and it still made the noise
