Cut that top part off on the fork , and you can run any compression.
instead of cutting maybe try spacers?
except hic
I have the alu bars so the Inner diameter is standard sized but the outside diameter is over sized
dude dont post stuff you dont know about. its actually right to cut the integrated starnut offBad idea to cut the fork. It's designed that way for a reason. Buy a new fork without the topcap.
