Lightest bars AND does FrID ST Bars work with SCS?
Maz.
Steel trees work with scs yes, and the lightest bars atm are probably the district v3's untill the addict bars are available.
To cut down bars just use a hacksaw its really easy, just cut it straight.
Ellie
You think this would be a pretty light setup:
Steel Tree Bars
Addict Deck
Proto SCS
Proto Sliders
whatever headset
and phoenix phrox?
Maz.
yes very light! But would be lighter without the scs and the steel trees, but still that setup would be verry light. I foyu wanted it lighter, id just get a random hic double clamp and district bars :)
Maz.
Yeahh
edit: but then with those adjustments Imo it would be too light but thats just me i don't like light scooters ahha
Collin.
If you want a really light setup, you should get
District Alu V3 Bars
A tilt scs
Phoenix Phorx/ Tilt legacy forks would look better
An addict deck
And the sliders.
The thing with getting aluminum bars/forks is you give up a lot of strength compared to chromo/steel parts.
But if you're not big and heavy and hit huge stuff you'll be fine
Ellie
Sorry, still kinda nooby about scooters :(
So:
Addict Deck
Sliders
Phrox
Tilt SCS light?
and district v3 bars or addict bars?
Griffiths007
The tilt light doesn't work with Alu bars. But I think addict bars are chromo. Didn't you just get a brand new scooter?
Ellie
Okay, so:
Proto Half Knuckle
District V3 WITH Slit
ICS
Tilt legacy fork
sliders
addict deck
this would run perfectly fine, right?
