tyler_
UN1C0RN
The new Proto Lite. Does anybody have a clue when the are going to release it???
I dont think they will ever be released. Its just not worth it for proto
You really don't, we experimented with chromoly decks for both regular and dirt scooters, they are a bad material for decks.
Heavy weight bar ends and wheels.
Make steel bolt barends and use fullcore Protos.
I really don't care if I end up with a 14lb complete, I want something I really ride hard and never worry about grinding through. Other than weight, what makes them so bad?
They are gonna release lites I thibk
it would bend i think, also try out a vertx i beam, not one broken and i dont think you will grind through that
Rubbing alcohol.
hair spray.
you have to use old people hairsprayi used hairspray once and it took over a week to dry
Dude, you have no idea what you are talking about.It wouldn't bend if you designed it right. And at least it would bend. Steel bends, aluminum snaps.
It's less efficient to make a steel deck, which is why it isn't going to happen.
Why would you use steel when you can use aluminum?
because steel or chromoly has better resistance to fatigue than aluminium so it would last a lot longer, even if it's designed to be the same strength.
They are coming out.
