Chris Harris
Chris Harris
put the spacer so that you cant put a back axel threw it, and hit the axel with a hammer... it takes like 2 minutes
Nick Granger said:its broke already so that doesnt matter. just hammer the shit out
Donald Miguel said:yikes, wouldn't that kill the shield or the outer race? Maybe something a little more flat..
It probably broke from going in crooked on the vice but if it is already broken it doesn't matter how you get it out. The best way is to open your vice just big enough for a bearing to fit through the jaws and lay the wheel flat on top of the vice and hammer out the bad bearing through the vice jaws and it will just fall through the opening.Tyler Wheeland. said:okay well i wanna replace the broken one
how do i get it out?
i dont wanna use wd40
That is exactly what i am going to do when I get my new bearingsDalton Kennon said:axle+extra bearing+tighten=success.
worked perfectly in mine.
and make u slide like a bitchDonald Miguel said:Before you use WD-40, READ
If you use WD-40 to get you bearings in, make sure it doesn't get inside the bearing. It will attract dust and act as a DE-Lubricant.
And even more important, do not get any WD-40 on the wheel itself. It will cause the urethane to deteriorate
Thats exactly how i get my micro bearings in ^Dalton Kennon said:axle+extra bearing+tighten=success.
lies.Apple iZackk. said:WD40 solves everything
do you do it one bearing at a timeRoyce said:Thats exactly how i get my micro bearings in ^Dalton Kennon said:axle+extra bearing+tighten=success.
