Proto problem
Ok so i have had my new proto wheels for a while but i havent riden them yet. so i went to put in the bearings and once they get inside the wheels all the way they just completley stop spinning.
they're brand new reds, and i did use an axel bolt to put them in but it just wouldn't tighten enough to push one bearing in all the way.
Erwin
this happens if u hit the bearing too hard and u crushed the thing that holds the balls (dont be immature) so yeah be more careful putting them in, use a piece of wood or a rubber mallet between the wheel and the hammer to not crush the bearing. this happened to me, my bearings stopped working after i put them in my eagles. so yeah you cant fiz the bearings, so yeah... lock.
Tanner!
dude thats not what he means. like i put them in using an axle bolt (I AM USING WHITE PROTO GRIPPERS AND REDS BEARINGS) and they barely spin. the wheels suck. why is this happening and whats andrews email address?
Tanner!
are you joking? im with my friends dad and hes an engineer and it isnt working. i kno the problem but its not fixable. when i put the bearing in the wheel, it compresses the outer bearing race until its touching the balls (be mature boys) and the balls dont spin at all.
zprestoe
Tehee
Tanner!
Apple iZack said:
Tehee
YOUR GAY :D
ride my scooter.
Michael Rankin
i had the same problem. i bored out the hub using a cheap pocket knife and it worked good. but do it little by little so you dont over do it.
Tanner!
brian thats how i did it. thats the tutorial i watched too. i knew how, but didnt wanna use a hammer so i did that way. and when i sed the wheels suck they really dont i was just mad
SORRY ANDREW
Steezeman
If you use a vice you shouldn't have any problems. It could be that by using the bearing method you're pulling the center of the bearing while the outside isn't moving as much because it's too tight against the inside of the core. But if you're using a vice you can press everything in equally.
Jordan Jasa
i did the way in that video, using a front axle instead though, and the bearings wouldn't go in straight. I had to use a hammer and a piece of wood to get it to go in. The bearings got messed up and at first it wouldn't spin at all but its gotten better somehow.
AnthonyPellino
Anthony Pellino
This happened to me too. I now I have a useless proto. I'm just gunna drill out the bearings with a drill gun because they are fucked now.
