Someone Help Me With My T3i
ChrisBrown
Hey guys, i need help with my T3i and i thought this would be the best place to put it. Well its been doing this for a while but i thought that if I just got a new fisheye (which i had been planning on doing before this started) it would fix it. Well everytime when I'm filming, and something like ap erson or somethign gets too close to the camera, it says "Movie Recording has been stopped austomatically" and it stops the recording. Also right before this happens like when i ride near someone while filming, on the LCD Screen there is a little bar that goes up, then it does the stop. Any Help would be helpful. Thanks
lukeakascooter
its to do with the memory card, if theres to much data trying to be writtin to the card it comes up with the level warning you the Bit Rate is to high and will stop recording once it reaches the top of the scale. theres not much you can do to fix it however buy a memory card which is of class 6 or above of about 8 gb at the lowest, should clear things up and dont get the brand Transceed or whever its called. sandisc is the best they also do an extreme class which writes up to 30mbs per second. :)
you might also want to look up magic latern (Firmware hack), it gives you sio many more options on your camera including the bit rate write speed :)
hope this helped :)
