BARSPIN HELP
dre
http://www.whipscooters.com/headset
also, you can make a headset press and take out the stock cups, and then reinstall them with the headset press so that they're straighter than before. That might help. Also, SEARCH.
And your sig doesn't involve girls. You must enjoy using your hands a lot..
mat
he said a paintball gun...
loosen those two really big nuts a tiny bit (the ones below the bars and above the headset, around the fork). you may need to take the bars off, loosen the nuts, then put the bars back on. also try putting some oil on the ball bearings in there. search.
ryankeong
even if your headset is tight you should still be able to barspinand whip i like mine a little tighter so it doesnt come loose and feels smoother when it spins
No, never ever use wd-40. Just clean out the headset and make sure you use some type of grease or oil to lube it. The stock razor grease is nasty as hell.
c4scooters
Barspins
I licked headset grease and it was nasty. Really bitter haha.
Try cleaning out your headset and putting wider bars on with barends.
blaine142
scoottwilliams said:
maybe it is just one noob who hasnlike 50 acounts and keeps making these threads
i cant remember what forum but someone said this same thing, i remember quoting it and agreeing but yea, tryin cleaning the headset then loosing or tightening the headset nuts
AX3D
mat said:
loosen those two really big nuts a tiny bit (the ones below the bars and above the headset, around the fork). you may need to loosen the nuts, then put the bars back on. also try putting some oil on the balls in there. search.
dude.. this is a scooter fourm, i do not want to hear what you do on Tuesdays.
Mattt.C
I own WSP.
just get a rag or watevr and clean the bearings (if you have a pro its this really groos sticky brown stuff) then regrease them with this sicko light grease (zinc oxide for all those nerds out there) and it spins lyk forever. :)
$8
mat
lmao nice first post bump
and wtf i vaguely remember this thread but now it makes no sense. did someone edit posts?
