Bearing help
tyler jordan
Ya I have eagle metal cores and eagle sport bearing spacers. I was wondering how u can the bearings out with that's kind of spacers in there
With my Skeleton Sig. Eagles, one was really loose, and fell out and the other was stuck in there. So i could always get the spacer out. What you could do is slide an hex key in through the first bearing, through the spacer and push it so it rests on the second bearing and smack the top with a hammer. Should work, but it should be agiven that the bearing survival rate of this type of procedure is very low.
