how do i tweak the spring to work everytime i do it it gets screwed up and the spring gets bent to much and i have to put like a bearing under it then it just falls out on like a whip flat
im pretty sure you have to cut a line in it so the spring doesnt touch the brake at all when the axle is through, so pull it out and try that. and to tension springs, use a lego brick, works much better and doesnt fall out
take the bushing from a skate board, cu tit in half, so you have a crescent piece, and it wont slip since it has a curve to it, and its plasticy stuff.
