BLAZER SCS problems
joshbeattie
its only about half an inch? and with the spacers in, it goes exactly next to the little lip in the middle of the compression? and i dont have a hacksaw, and the bike shop across the road charges ALOT to cut stuff down, so that should be a last resort :/
Bobby R
Yep, that's the problem. You need to get another spacer or cut the fork a little bit, the top of the fork needs to be below the lip, not right next to it.
Get a new spacer or cut the fork then put it all together, you'll be fine.
joshbeattie
only just read this, cheers man:') but since i have a starnut in the forks, and installing another is a blag, ill just get some more spacers:p, but cheers, you've been a massive help :like: and cheers to anyone else who's given advice aswell :')
Broccoli1
no, the forks are threadless? they have threads inside them for hic, but that dosn't have anything to do with scs..:confused:
HIC and SCS both work similar: You use a compression Bolt from the top of the Fork, either on top of an HIC shim or with a Top cap and SCS.
If the Fork is Threaded INTERNALLY there should be no need to drive a Starnut in to the fork tube since the Fork comes with a Threaded hole for the Compression bolt.
The term "Threadless" when speaking of Forks, applies to the OUTSIDE of the fork tube.
joshbeattie
right, confused here, mainly because skatehut told me to take of the hic and install a starnut, although they could be wrong :l the forks had the hic with them, and it had like, a giant bolt that screwed into the forks, with a hole in it, are you saying that i could have left that in and used it instead of a starnut?!
joshbeattie
plus, does anyone know where i can buy some bolts for my scs? the ones that come with it are really crap, and nearly rounding -_-
Broccoli1
Yes.
...but the bolt that came with the HIC will obviously have to fit through the hole in the Top cap used with SCS.
99% of them use the same bolt but of course theres always some that could be a different size.
Skatehut should have replacement compression bolts and it is a good idea to replace them as soon as you notice any Rounding of the allen socket.
joshbeattie
Yes.
oh ----- i forgot about the bolt the hic came with, not sure where it went :/ im using the bolt that came with my headset at the moment, and yeah i cant find any on skatehut, or anywhere else, and some dickhead at my local went and rounded one of the bolts, so..any tips for getting that out?! :/
joshbeattie
worst things just happend, and i need help, the second bolt up on my scs is rounded, it wont come out AT ALL, i got the new bolts and put them all in, and tightened them up to take presure of the stuck one, but it wont come out no matter what i try, someone help, please:mad:
Broccoli1
You are probably going to have to cut it.
