Blunt IHC Fork Problem - HELP!
Vji289
I just got the Blunt Declare IHC in the mail earlier this week and when I tried to slide my bars over it to tighten my clamp, it wouldn't go down all the way. It stops going into my bars right around where the slit ends. Do I need to make the slit longer in order for it to slide in, or is there another problem (Dully Noted Sentence...Sorry) I'm riding an Inward T bar by the way.
Vji289
Well, I've already stretched out the slit so I'll try sanding the shim and inside of the bar. Thank you so much, this sounds like it should work.
