So you put the brake in the position its usually in when its on. then put the bolt through the hole on the deck and push it until it goes thru the brake, but not all the way through it. put the spring on the bolt, then finish pushing the bolt thru the other hole of the brake and through the deck and put the bolt on.
Its not that hard.
