Compression Kits
stukwon-do
Hey guys, I am having a lot of trouble with my forks/headset that i will not bore you with but, what i do need to know is, How long are the bolts that come with a compression kit, where can i buy such a bolt and what size star nut do i need if i'm running Wee Bars!? As it would cost me a lot of money to get a whole compression kit sent over if i can just get the parts from a hardwae or bike store etc.
Get a over sized starnut from a bikeshop and that will probably come with a top cap and a small bolt for the starnut and take that small bolt in to like a hardwere store or a place that specializes in nuts and bolts adn ask the for a really long one wich is that same size(probably be handy to measure from the forks to the bars to get th proper length) and there you have it a cheap compression system.
Brian Boston
Finding the bolt is going to be REALLY hard. Im pretty sure the ones for the SR compression kits had to be specially ordered.
Jdbug_rob
you can make your own pretty easy
step 1: get a mtre long double sided bolt
step 2: cut how much you need.
Step 3:put 2 nuts on the end and tighten them into each other
