Crows problem
D ∆ V I D
Basic Bunch
im so excited i got my new hic crows, and i realize the shim is inside of the bars. I cant get it out and its getting me mad,. is there anyone who knows how to get the shim out so I can actually use HIC
DavidCronin
i say try to pull it out with a flathead screwdriver
Matthew Wyman
Matthew Wyman
yea i got mine too its not the shim its the headset when u tighten it it goes into the headset thats why it feels stuck u have to hit the headset cup down then pull it off
you just got to break it in a little
Jacek
what? a headset is the spinny thing on that tube on your scooter dude. its not any type of shim.
yea just try to get some thing kinda shaped like an "L" (maybe ur allen keys) and try to hook it in there and pull down. just tinker with it for a bit.
Matthew Wyman
Matthew Wyman
ur dum the shim when i tighten it goes into the top headset cup and thats why the shim or bars are stuck and wont come off YOU DONT KNOW WHAT UR TLKING ABOUT
D ∆ V I D
Basic Bunch
no its not even installed, the bars have just the shim stuck inside, and there isnt a top cap or a bolt. inside, just the shim
Matthew Wyman
Matthew Wyman
well thats how they come u have to have the bolt and top cap sorry my mistake but im right with that problem that u will deff have and my shim didnt come inside the bars it was out
Get something really fracking long and shove it down the cap hole in the crows
maybe that'll work? haha, i dunno.
D ∆ V I D
Basic Bunch
i just got back from a bike shop and they couldnt do anything, so im just going tostick with scs and cut the bars before the shim
Matthew Wyman
Matthew Wyman
i can get it out it happened to my friend take a flat head screw driver and stretch out the bottom slit on the bars then get another strong person to grip the shim with like plyers or w.e is best and then while they pull out make sure ur stretching the bottom of ur bars
thats how u get it out
This is how you do it. You take a flat head screw driver, and you hit the inside of the shim until it keeps rotating so the slit of the HIC and the slit of the bars are aligned. Then you take the screwdriver and you hit it inside the middle of both the slits and the HIC will come out...keep hitting it.. it will work
