Folding Mech Problem?
tarrymonz
this shits ghetto as
wobbles like a bitch
its bolted with 3 bolts
the right sizes
but jiggles
might be in the headset
idk
any suggestions on conquering the problem?
ps: my razor pro's near a year old
K
Kieran Mayhew
Guest
try tightening the mech support and the bolts
if not its probs your headset
K
Kieran Mayhew
Guest
probably need a new headset then if you have been riding it for a year
Brian Boston
Rebolt the mech. When you put the middle middle bolt down, make sure you are tightening it so the bolt moves down when you tighten. I used to have the problem when i would be turn the wrench and the bolt would move up, i flipped the bolt over and it would move down instead. It also helps to remove the little plate that is on the front of the mech that has 2 (or 4 bolts depending on model) allen head bolts in it.
Than, tighten up the headset! Them thing need fine tuning.
