French ID Forks Problem
JoshNunez
So I got some new french ID forks and they are light and strong but....
there seems to be a problem.
Whenever I tighten the fork, I can't tighten it too much or else it doesn't allow the wheel to spin, lucky 110mm to be exact. And whenever I don't tighten it all the way, the wheel wobbles and is annoying.
Is there anyway I can fix it? I have washers and everything.
JoshNunez
The wheel is rubbing up against my fork, do I use small washers to fit in between the two sides of the wheel? Is that how this damn thing will work?
Thicker washers. I have a french ID fork as well.
you need the washer to go between the wheel and the fork wall.
