FRONT BRAKE??
Eric Magray
good im glad yous r all making it better cuz it really pissing me off (the front brake that is) i hate it and want it to be better so just post pics and shit and one thing is that try to drill the hole on a downward angle(if u use that method) instead of the way i did cause its really hard to step on the way i made it straight
farmboy uk
lol i don't think it was an insult to your idea lol just that he didnt make it perfect. By the way what does your signature say????
Eric Magray
Pete Pachota said:
Wow, then sorry for the idea.
no it wasnt your idea that was bad it was the way i made it the spring i used is messed up and the part that touches the wheel starts to hit the fork and cant turn i just need to get a new spring
VillageFox
i made one. it work pretty good, because i made the thing that stops the wheel bigger and same with the part you hit with your foot. i also put griptape on both ends.
silksimon
i like higgi's idea i'm working on one while my nose is hurting. hey vfox get some pics i wanna see what it looks like.
VillageFox
im not posting anymore pics til i get a new camera. they come out like crap.....unless i get lucky and get a good one, ill try later.
and about the griptape wearing down the wheel, i only used it once on the flat ground so idk if i will in the long run.
Eric Magray
it shouldnt wear it down as long as it stops the wheel right when you hit the brake otherwise it will if you just let the grip grind on it but if you dont you should be fine
