NickGraham.
Byron im definately gonna try that. cause nothing seems to be working at this point.
First, thats not a dust cover and not a star nut.NickGraham. said:cups arent bent. and I tried not using the dust cover, just the starnut and same issue but worse.
this is what i did it was just like yours now it is fineByron Barger said:i had the same problem when i used all stock. I just took the bearings out, clean the cups with a rag and the bearings and let them soak in 2 in 1 oil and put it all back together and it worked amazing for a really long time.
AJ Iorio said:First, thats not a dust cover and not a star nut.NickGraham. said:cups arent bent. and I tried not using the dust cover, just the starnut and same issue but worse.
It's a race, and a headset nut/compression ring.
Second, if you're sure your cups aren't bent..
I'm thinking your crown race (thing you hammer onto the forks) or top race (what you called a dust cover) is bent.
Are you greasing your headset? Do you even have a race on your forks?
Try cleaning out your headset. Take out the bearing cage for the top cup, and roll it in circles on a paper towel to get ALL the dirt and debris out.
Then grease it.
If you took out your cups to switch decks, and everything else you say is true, I'm thinking you definitely put the cups in crooked.NickGraham. said:AJ Iorio said:First, thats not a dust cover and not a star nut.NickGraham. said:cups arent bent. and I tried not using the dust cover, just the starnut and same issue but worse.
Then grease it.
AJ, nothings bent. and Im gonna try cleaning everything soon with oil like byron said. but for the most part the ball bearings are completely clean, two of them that I tried are actually brand new. so idk.
... XT headset bearings =/= Razor headset bearings?NickGraham. said:I never took out the cups when I switched decks, I just used my bearings, forks, bars, and wheels. but then when I put my bars and forks back in, it all started. but I kept my bearings in the xt deck and took the brand new xt bearings for my headset. so there's no crooked cups.
The little ring you hammer onto your forks is a crown race.NickGraham. said:Im really confused dude. translate to my language.
You didn't put on the FSA crown race? Or you did, but you didn't switch it when you used the xt bearings?NickGraham. said:ohh. and nope, I didnt do that.
R.o.b said:Are the bearings in the right way?
bottom cup the balls face up
top cup the balls face down
