help!! brake problem.
molewood4
with my blade brake, i used the spring it came with but i had to glue a bearing and spacer so that it would work, but it keeps coming out i used super glue because thats the srrongest i have, i want to use my pro model spring but i cant stretch it enough or push it down enough, so i need help.
alexiorio
Sam Gregory said:
how will that help? surley using it would make it less springy thus making it easyer to put in.
What I do.
Use a brand new spring. Put the bolt through the scooter, and one side of the brake, but don't have it coming through the middle at all.
I like to use the tip of a socket wrench, and push on the spring. Because if you push with your fingers its almost impossible. But yeah when you push it with that, get the bolt through completely. That's the easy part, it's a bitch gettin the bolt through the other side of the scooter.
Yeah I work on everybody's brakes at my local lol.
Lil Steve
Alex Iorio said:
What I do.
Do that.
locklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklocklock
