Help on threadless fork?
cisys
Hi , im pretty new to scooter-ing and i got a Mgp team edition , so far it has been pretty nice but the head set is pissing me off . I want to change to a threadless fork but i got no idea what i would need to fit it on my team edition. all i know is that I need a threadless fork and a threadless headset and im good to go? can i use the stock team edition bars?
ohh and i got trouble with tailwhips(i know theres a trick side of the forum but i just dont wanna create to amny threads) I can do the full rotation on the tailwhip but the deck will land to much to the right for me to step on it , any tips?
Thomas Madd
First of all, you need threadless forks(Phoenix Phorx), threadless headset(Blunt Battle Headset) and a compression system (Proto SCS)
Instead of a locknut, the compression pulls the fork up which makes the compression tight and with no wobble.
With tailwhips just try to do it off a ramp and once u have the motion and how to land it then dou it on street
Jimmy C
like he said you need threadless forks compression and headset. theres more than one fork then phorx and if you look around on here you can find everything you need relativley cheap. and in pretty good condition. theres 2 types of compression. one is scs and the other is hic. with scs the bars sit on top of the forks and with hic the bars sit over the hic kit and forks. with tailwhips try to kick a little harder and use your wrist a little more. depending on the kind of person you are you can hop higher but sometimes it just wont help
Hamish C
theres also ihc which would work with his bars where as hic wouldnt, also ics would work, if hes only beginning theres no need to confuse him with scs hes better off to get a pair of ihc envy forks which will come with the ihc compression and a threadless headset of his choice.
gjdadj
the cheapest way to run compression on youre scooter is:
get a threadless headset
get threadless forks
get a ics compression kit,
approx $150 or so, plus you need help putting in the starnut.
and tailwhips....... team eds are pree heavy for beginners, id do it on a rup, and id do it off a small ledge, also, practice every part of it induvidually, practice practice practice practice.... simple.
cisys
Thanks :D But at the place i stay theres only one store that sell district parts and ordering online will cost a bomb . Any idea if the forks/handlebar are good or bad?
cisys
are there any recommended / popular threadless headset that will fit the MGP team edi? If they dont sell the head set and im going out to a bike(BMX)store to get a headset what do i look out for?
cisys
Are there any popular headset that will fit the MGP team edition ?
And if i cant find that headset and go to a bike(BMX) store what must i look out for?
