Help with Superman Deckgrab.
david327
I need help on landing a superman deckgrab, i can get high enough into the air, grab my board then push out, but on the way back down i always miss land.
Any help you could give me on gettin back on the scooter.
ummm... i messed with my bar-height while learning them because i find it easier to land with the bars right down.... umm apart from that maybe try throwing your deck into position and really just """practice"""
Kenny O.
once you grab your deck, just throw it down and put your other hand back on, dont try to go for the huge extension. What i did was work my way up from no footer deck grabs and i started extending it more and more each time.
david327
thx for the comnents ill just keep trying them and farmboy u said u was goin to ride port with ryan will i ride with ryan port might see u there some time.
david327
thx for the comnents ill just keep trying them and farmboy u said u was goin to ride port with ryan well i ride with ryan port might see u there some time.
Dunno if I should give advice about this cause I suck at superman dgs but what helped me to get a decent extension is to kick my feet away from the deck so my body would fly upwards and then try to push your ass down to band yourself to be perpendicular to the ground.
And if you cant land it just try to boost some more air.
dre
I can't do them over box jumps, but I can do them on a trampoline. It might be easy to start with that and get them real good, and then do what Kenny said...
Pretty much get a fair amount of hight..
Kick ur legs down grab ur deck and throw outwards..Its probably best to get as much extension because it springs ur legs back in, easier to land!
Spot ur deck and plant ur feet on it leaning a bit back..
farmboy uk
i know it sounds wierd but if you want to catch it firmly try to stamp your feet onto the deck as if you were going to stamp through it if you know what i mean. its like in martial arts when they tell you to hit through the board rather than just hitting it
