help!!!
jonpo
my brake is rattling and i did the coin trick but it still rattles wat i do
and my scooter has to be solid i cant deal with it not being solid
Aaron
Take the spring out, put it in a shifter, tighten the shifter...
That will make the spring a bit tighter.
Then put something big under it, not a coin, something bigger - bearing or something.
a shifter is a spanner thingo that has a little barrel on it that you roll up and down and it adjusts the width of the two sides so you can adjust it to any size
