helpedy hellp help me edit: need more helpey help helper help stuff help... help sttff
AX3D
So we cant reinfoce the '08 model forks.. and since i ride 1 piece bars i cant exactly use them.
I used to do the method of reinfocing them then stacking thread bits on the reinfocment.. but now i cant do that.
So im pretty much fuckeed cause I need that reinfocment stacking thing to keep the bars from coming off.
also, i already tryed finding a pole that fits the forks to renfoce with, and i cldnt find any at all.
little help cause if i cnat find anyhting im fucked since i dont have any stock bars.
bascially what im asking is is there a way to get 1 peice bars to fit on the new model forks.
koenscoot
So ride bars arent the exact size for your fork?
And you need a longer fork to run a quad clamp to make them solid?
Only thing i could think of is swap forks with some one who doesnt have 08 forks and ride bars.
I reinforced my 08 forks with a 3mm thick 1" stainless steel tube which had been cut down the tube and squished in to make it fit in the fork and then welded in..
AX3D
no, they just suck and come off if the fork it too short lol. i need some new bars.
but thx for trying tho
[ScooterPeru said:
make your own forktube :), i did that for my crusier scooter
how, did you weld it?
AX3D
bump.
well whatever.. im going to some metal place tomorrow to try and pick up a solid pipe to reinfoce with so that i stop breaking forks lol
BTW, sorry the search button is not working for me right now, idk if its the same for anyone else but what is the
INNER DIAMETER and OUTTER DIAMETER for 1 piece bars (like the handle bits and the stem bitt)
and yee i know you dont actually need the inner diamiter fiir the handle bits so yee, so if i could get that info ASAP, or I'll love you if you cna use the search botton for me acuse it keep sending me back to the main page!!
edit:
K so i got my friend to seach it.
He found
"4130 chromoly in 1 1/8" I.D. for steer tube and 7/8" O.D. for handlebars"
So what is the OD of the steer tube then?
Jack;
od of bars are 1 1/4" id is 1 1/8....why do you think we use 1 1/8 headsets for forks and 1 1/4 clamps for bars?
Brian Boston
Im not sure if this would work, but could you put the reinforcement tube in the fork from the bottom instead? I can't remember if they put that lip at the bottom too
koenscoot
No lip.
on 08 pros the hole forktube is thicker
Try and reinforce it that way.
AX3D
Tryed that, but I'm not actually using a Razor for at the moment though, but im using a fork thats a bit longer and similar with no lip.
Royce said:
i just used some t-tube and tape to reinforce my new pro forks
if you have to use tape its not going to do anything, reinfocments alone arent even that great since the metal can still crack easy.
