how do you install a compression system into a inward fork not using inward compression
Michael Rankin
ok ralph. its very simple. you can use inward or sr inverted compression. you install the oversized starnut 2 inches into the bars. then you feed the compression bolt through the bottom of the fork and you tighten it. theres your compression.
