How to fit 110mm wheels on a pro model
Brian Boston
I'm sick of all the threads about it. Getting them on is simple. Take the front wheel off your scooter, on the bottom of the fork you will see a black cap. Get a screwdriver, wedge it under the cap and pop it off, put the wheel on and bam its fine. Now for the back, if the yak dosn't fit perfect in there you have 3 options...
-ride the wheel until your wear it down
-take a hammer to the brake and knock it up a little (not recomended)
-take off the wheel and brake, get a metal file, and file the deck in a little so that the spring is moved back more and the brake is a little higher so the wheel fits.
If you make a thread about fitting 110 wheels its getting locked.
lol haha yeh that is true i just bend the spring in abit then put 20cents int the scooter supper glue it to the scooter so then when the spring hits the 20cents its got tense on it
