How to lower a MGP brake?
Zaηe
Keepin' Peace
Cutting it.
Stick a bearing under the spring.
Get a real bolt for it.
nitroRCs
I dont think you can lower a brake. I know by butting things between the deck and spring that that will stop rattle, but i dont think you can make them lower.
Maybe get a 110mm??
nicaz
Maybe get a 110mm??
put paper in between the deck and brakeee, should make it stop rattling a bit.
Thats how ya do it bruuuhzzz
tarrymonz
yeahbro
if it sits high
press on the brake so its almost touching the wheel
and see that gap between the brake and the deck
stick a coin or a few pieces of paper in that crack
and it should stay there if you have enough tension against it
