How to make Trolley/wider bars out of your Stock Pro Model Bars
Kroto
.. If your asking how to make your razor pro bars wider all you do is shove a pole in there and bolt it
Kroto
idk figure it out, common sense
and seriosuly why are you asking how wide to make them, MAKE THEM AS WIDE AS YOU WANT
BrandonWeir
and you drill holes in it to bolt it? what size are the boolts?
Depends on how big the holes you drill are. Generally the holes will be the same size as an axle. Find two bolts and some spacers (you can use bearings as spacers), and find a drill bit that's approximately the same size. Then drill through the two holes that are already there from the little buttons, measure and drill holes in the crossbar, then bolt it and you're done.
so would it be bettr to use axles?
BrandonWeir
Not necessarily better but that's what I always did because then I could use a bearing as a spacer easily. It was simpler, because a front axle and 1 bearing was the perfect size. I couldn't really find any other bolts that were that size and that short without cutting some.
